EDIT BOX that recieves only numbers?
Postby KG_is_back » Tue Apr 08, 2014 8:11 pm
Is it possible to restrict edit box to recieve only numbers as valid data? (like in windows when you enter non-number character it will not get written - instead you get a "ding" sound).
KG_is_back
Re: EDIT BOX that recieves only numbers?
Postby chackl » Tue Apr 08, 2014 9:07 pm
The easiest way would be to convert the string to the data you loke to have and then Feedback it to the input string of the editbox ;)
Then you neet to "send Trigger only on finish" to true
And adding a Switch to get also input back ;)
I did an short simple example ;)
Regards
edit box mod.fsm
(1016 Bytes) Downloaded 943 times
chackl
Postby Nubeat7 » Tue Apr 08, 2014 10:01 pm
i did one once here: viewtopic.php?f=2&t=1421&start=20
it also has some optimizations in using the edit box
and it has a restrictions module inside, where you can set ruby restrictions, this one takes only numbers everything else is gonna be ignored
but this one is only for int values...
editbox_nubeat_v2.fsm
(4.66 KiB) Downloaded 930 times
Postby KG_is_back » Tue Apr 08, 2014 10:31 pm
chackl wrote:The easiest way would be to convert the string to the data you loke to have and then Feedback it to the input string of the editbox Then you neet to "send Trigger only on finish" to trueAnd adding a Switch to get also input back
That's how I'm doing it already. I was more looking for something that would not even allow you to write numbers while editing... It's not really biggie... I'm just trying to make my plugin idiot-proof by not allowing to input random stuff.
Is it possible to make edit box within ruby?
KG_is_back
Postby Nubeat7 » Tue Apr 08, 2014 11:11 pm
yes you can make a ruby edit box but i know no way of restriction while typing
here it would just 0.0 if you type wrong..
editbox_ruby.fsm
(984 Bytes) Downloaded 916 times
Postby Nubeat7 » Tue Apr 08, 2014 11:20 pm
here using regex to extract floatingpoint from input string
editbox_ruby1.fsm
(995 Bytes) Downloaded 919 times
