Multiple Menus
Multiple Menus
Postby jerry » Fri Jan 27, 2012 3:59 pm
I have not been able to figure out how to have a main menu which presents other submenus in flowstone, then be able to exit and go back to the main menu? Please advise.
jerry
Re: Multiple Menus
Postby jerry » Sat Jan 28, 2012 1:00 pm
Maybe the front panel can act as a main menu, but can it call other front panels to act as submenus? I have gone through most of the examples but cannot find an example of this.
jerry
Re: Multiple Menus
Postby DSP » Sat Jan 28, 2012 4:05 pm
I think what you are asking is how to switch on and off various menu windows.
This can be done using the multiplex selector module on the V input of the Module GUI. Basically switching off and on the view (so it is invisible or not).
Here's an example, by switching the switch two different windows can be displayed.
Switch View.fsm
(54.81 KiB) Downloaded 1220 times
DSP
Re: Multiple Menus
Postby jerry » Sat Jan 28, 2012 5:27 pm
Thanks, that helps a lot. I can proceed with multiple menus now, before I was hitting roadblock!
jerry
