how to calculate combfilter?
hi all, i try to make a combfilter referring to this papers:
https://ccrma.stanford.edu/~jos/fp/Signal_Flow_Graph.html
it was easy to built the main construct, my question now is how to cook the parameters 'frequency' and 'resonance'
atm i set the range for delaytime from 1 sample to 64 (freq) which sounds fine and what i found out 0.01..0.49 for the feedforward gain and 0.01..0.99 for the feedbackgain (which would be the resonance..)
this combination sounds pretty good but shouldnt i calculate them in any way?
so how to calculate the 'frequency' parameter range, and how the resonance (feedforward and feedback gains) - should they be exponetial? or is it a case of taste
i`m also not sure if they are related to the delaytime?
it should be used the same way as the standard filters lp,hp,bp & comb in with freq and res parameters
thx
thx
Re: how to calculate combfilter?
Hey Nubeat,
the transfer function of that comb filter is
So there is a numerator which has zeros (dips in the spectrum) and a denominator which produces poles (peaks). Now the numerator dips occur at frequencies
f1, 3*f1, 5*f1, ..., where f1 = f_Nyquist/M1.
Similarly, the denominator peaks occur at frequencies
f2, 3*f2, 5**f2, ..., where f2 = f_Nyquist/M2.
The effect is strongest for g1 or g2 approaching 1. However, if you choose g1 = g2 and M1 = M2 the dips and peaks will cancel. But why don't you just hook the thing to a spectrum analyzer and experiment for yourself?
1 + g1*z^-M1
H(z) = ------------
1 + g2*z^-M2
thank you martin, sadly i don`t know how to cook the 2 parameters out of this formula.
i don`t understand the z-transfer and its really difficult to find noob papers on this, specially in german..
i prepared a basic schematic, would be great if you could explain there how to use this formula to get the required parameters
thx
thx
combfilter.fsm- (1.58 MiB) Downloaded 1484 times
Frequency is simply a reciprocal of delay time... you don't need Z-transfer to calculate that.
For the resonance, I have found no general way how to define resonance in comb filter.
You can view the circuit as two comb filters in series, one feedforward and one feedback, so their transfer functions simply multiply. The feedforward filter has maximum attenuation (dips) equal to (1 - g1) at frequencies f1, 3*f1, 5*f1, ... (see above). In between those dips, at frequencies 2*f1, 4*f1, ..., there are gain maximums equal to (1 + g1). So for g1 = 0.5 you would have -6dB dips and +3.5dB gains.
For the feedback filter, the situation is just opposite: You have peaks equal to 1/(1 - g2) at frequencies f2, 3*f2, ..., and minimums equal to 1/(1 + g2) in between. +6dB peaks and -3.5dB minimums for g2 = 0.5.
I made a few modifications to your schematic. Note that the JOS diagram shows the second stage in feedback topology, so that's an important change. However, then it does not make sense to have common knobs for g1, g2, and M1, M2, respectively, because then the overall transfer function will be unity (refer to the expression for H(z) above). So I provided individual knobs for each parameter.
Then a few minor details, like you had the volume control after the clipper, which led to unwanted clipping sometimes e.g for white noise, so I put the volume control before the clipper. I also threw in a rational mapper for the g's so you can tamper the knob response for a perceptually uniform function.
It is fun to play with it. You will find that the feedback filter produces pitched sounds because the peaks form a series of (odd) harmonics.
Not sure I answered your question, though?
combfilter_02.fsm- (1.13 MiB) Downloaded 1451 times
thanks, ok i slowly get it now
so in fact i could name the feedforward version 'comb notch' and the feedback 'comb peak' or?
