logarithms in ruby - working?
Postby tester » Tue May 20, 2014 8:59 am
Something like this.
Does it requires something else?
ruby-log.fsm
(324 Bytes) Downloaded 876 times
Re: logarithms in ruby - working?
Postby CoreStylerz » Tue May 20, 2014 12:25 pm
use Math.log(num,base)
http://www.ruby-doc.org/core-1.9.3/Math.html
PM me if you are interested.
CoreStylerz
Postby tester » Tue May 20, 2014 6:24 pm
Nope, not with array that way.
ruby-log.fsm
(330 Bytes) Downloaded 860 times
Postby Nubeat7 » Tue May 20, 2014 9:11 pm
you need to do it with each array element, using 'each' in a oneliner like this:
output 0,@arr.each_index{|i|@arr[i]=Math.log(@arr[i],2)}
Postby tester » Tue May 20, 2014 10:53 pm
Okay, thanks on that.
Postby RJHollins » Tue May 20, 2014 11:16 pm
Good stuff NuBeat !!
Thanks for helping us all :)
Postby tester » Tue May 20, 2014 11:53 pm
There is one problem.
At each restart I get an error (see attached pic) and must retrig the module.
Postby Nubeat7 » Wed May 21, 2014 12:18 am
hmm looks like it does the operation on loading, also when you click insideand change space or something it recalculates the array which contains the already processed values, like this the values are getting smaller till they are aout of range (minus)
just put it in an event methode, to only get triggered from input, i think this should solve the problem ( it does here )
Postby tester » Wed May 21, 2014 12:38 am
I added afterload/dupkicate triggers for input, works too (no error display in schematic).
