filtering array of strings (ruby)
I'm stuck with something, and conceptually I found different way do deal with it.
I'm looking for following solution.
Let say that I have array of strings, like this
aaxxxaayyy
abqqqcdwww
Now - I'd like to compare two sections within each string in the array, and if these sections match - output 0, if don't match - output 1. Thus array of 0's and 1's will be on output.
For above example - first string contains matching pair (lenght = 2, start1 = 0, start2 = 5):
aaxxxaayyy
How to make it?
aaxxxaayyy
abqqqcdwww
aaxxxaayyy
How to make it?
Re: filtering array of strings (ruby)
If I understood you right, it could be done like this:
I suggest reading this. It's about regular expressions in ruby.
result_array = string_array.map do |str|
str =~ /^(..)...\1/ ? 0 : 1
- TheOm
Best way is to join arrays removing duplicates(union) get common elements(intersect) and then check differences by removing all elements in array1 contained in array2(difference).
PM me if you are interested.
CoreStylerz - Posts: 327
I may have messed something last night, so I re-type.
(It's a part of a project, that I left here somewhere around, and I'm rebuilding it into ruby due to multiple array operations).
Input array will be something like this:
f1a->f1a/a2
f1a->f5b/a3
f3c->f3c/d2
f3b->f5a/a3
Output array should be:
0
1
0
1
String to find and compare within lines is 3 elements long, first element starts at fixed position N1, second element starts at fixed position N2.
Output array feeds an external module with multiple inputs to sync.
f1a->f1a/a2
f1a->f5b/a3
f3c->f3c/d2
f3b->f5a/a3
0
1
0
1
Here, this will work and you can also change your n1, n2 and len if you need to.
n1=0 #position of first occurence
n2=5 #position of second occurence
len=3 #length of the string to find and compare
output_array = string_array.map do |str|
str =~ /^.{#{n1}}(.{#{len}}).{#{n2-n1-len}}\1/ ? 0 : 1
- TheOm
Thanks, sorry for delay in my response, busy days, will look into it tomorrow.
