another ruby and arrays thing
I just realized, that I don't have one solution under my hand, and I'm using wrong one.
Let say that I have 2 arrays:
array1 (strngs):
string1
string2
string3
string4
array2 (boolean ints):
0
1
0
1
On output I'd like to have only rows that correspond to 1's.
For above example, output array it would be:
string2
string4
How to make it in ruby?
array1 (strngs):
string1
string2
string3
string4
0
1
0
1
string2
string4
Re: another ruby and arrays thing
I assume this is related to your other thread?
Do you only want the strings that don't match in your new array?
input:
[ "f1a->f1a/a2",
"f1a->f5b/a3",
"f3c->f3c/d2",
"f3b->f5a/a3" ]
result:
["f1a->f5b/a3",
"f3b->f5a/a3" ]
Then use select instead of map, like this:
input:
[ "f1a->f1a/a2",
"f1a->f5b/a3",
"f3c->f3c/d2",
"f3b->f5a/a3" ]
result:
["f1a->f5b/a3",
"f3b->f5a/a3" ]
n1=0 #position of first occurence
n2=5 #position of second occurence
len=3 #length of the string to find and compare
output_array = string_array.select do |str|
!(str =~ /^.{#{n1}}(.{#{len}}).{#{n2-n1-len}}\1/)
- TheOm
If that's not what you want, you could do something like this:
array1.each_index do |i|
array1.delete_at(i) if array2[i] == 0
- TheOm
Second solution will be more appropriate; it applies to different sections. There are various filters (formula & range based, content or comparison based) which define whether to pass values/rows/strings (1) or not (0), and such module outputs appropriate entries according to 1's indexes.
Thanks.
Thanks.
Small problem here.
How to adjust it to have multiple arrays pass through that way?
(and how to fix it?)
issue.fsm- (583 Bytes) Downloaded 798 times
I would do it like this
k.fsm- (538 Bytes) Downloaded 999 times
- TheOm
Thanks!
