'is playing' stream primitive doesn't work
i think we already had this theme up a while ago, just wanted to confirm this bug..
the 'is playing' stream primitive doesn't work when exporting it as vst
here is the example - i tested it in cubase and renoise
if somebody could confirm this it should be reported, thx.
playtest.fsm- (14.58 KiB) Downloaded 1075 times
Re: 'is playing' stream primitive doesn't work
Nubeat7 wrote:'is playing' stream primitive doesn't work
It does work....
but packing the 'is playing' output , like in your fsm...there's no output...don't know why.
and in which case does it work? i tried all 3 cases (poly, mono, mono4) and no of each did work...
I just used a mono readout attached to prim.
don't work here...
anyway it should make no difference to use it in poly, mono or mono4..
Broken here in Reaper for the posted Mono4 schematic.
thanks for confirming, should i report it using support@dsprobotics.com or do you trog or exo get in touch with malc soon? to be sure they get it..
Yeh nubeat7...there defiantly seems to be a bug there somewhere....
In the meantime, here's a way of working around it that might help...
I'm testing in FL....
Nothing works in this pic....
Then, for some reason, just drop this into schematic..
And everything works....
give it a try with your fsm...weird...
thanks billy, i know, normally i use the green version but i need the blue one in my actual case..
i reported this to the support.
I didnt clarify this...but dont connect the green/ruby
prim...just drop it into schematic un-connected..
and still use the blue.
Users browsing this forum: No registered users and 31 guests
