SAMPLER vst or exe?
SAMPLER vst or exe?
Postby apoc123 » Thu Jul 17, 2014 9:00 pm
does anyoneknow why when i create a sampler, as soon as i connect the ouputs to an asio and try to export as a vst, it only lets me make an exe??? i have the full flowstone version.... help guys!!!
apoc123
Re: SAMPLER vst or exe?
Postby Nubeat7 » Thu Jul 17, 2014 9:40 pm
do you have an input?
if you have no input (midi for vst instrument and audio or audio and midi for vst effect) you only can export as an exe.
Postby trogluddite » Fri Jul 18, 2014 12:38 pm
To make a VST, you need all of the 'workings' of the plugin inside a module container, but the ASIO/MIDI primitives outside the container. The connectors where you join your module to the drivers then become the inputs/outputs of the plugin (audio links must be blue mono).
For an exe, everything, including the driver primitives goes inside.
Postby apoc123 » Fri Jul 18, 2014 7:55 pm
nubeta7.... yes I have the midi in selector and the keyboard highlighted.......thanks for the help though!
trogluddite.....I think that was my error I had everything inside!!! thanks man!!!
apoc123
Postby apoc123 » Sat Jul 19, 2014 10:49 pm
Can you guys edit this sfz player so that I can export it as a vst and load sfz....it only lets me make a exe........help!!!
SFZ PROBLEM.fsm
(72.12 KiB) Downloaded 948 times
apoc123
Postby Exo » Sun Jul 20, 2014 12:05 am
Hey, you just need a module with a midi input and two mono outputs.
I've modified your example....
SFZ PROBLEM.fsm
(74.97 KiB) Downloaded 1014 times
Exo
