VELOCITY SENSIVITY ON A SYNTH???
Postby apoc123 » Fri Jul 18, 2014 8:51 pm
hi guys,
I need help, I need to know how to make my synth velocity sensitiv]....no matter how hard I press the key it still plays at once level....help please....thankyou my friends u are SYNTH GURUS!!!!
apoc123
Re: VELOCITY SENSIVITY ON A SYNTH???
Postby TrojakEW » Fri Jul 18, 2014 9:15 pm
In midi to poly module there is velocity output. Multiply it with your signal and you have what you want.
TrojakEW
Postby apoc123 » Sat Jul 19, 2014 11:04 pm
GOT IT ...THANKS TROJAKEW!!!
apoc123
Postby musella » Wed Mar 15, 2017 11:58 am
Hello,
I would like to have a precision...
It's written : "multiply it with you signal..."
But how can I multiply ?
Thanks a lot,
musella
Postby musella » Wed Mar 15, 2017 12:02 pm
Hello,
How can I multiply with my signal ?
I would like to have a velocity response when I hit my piano key and the sound Flowstone can do !
Thanks for your help !
musella
Postby rdgaudio » Thu Mar 16, 2017 9:50 am
In the search bar search with "Multiply"... You will find "Stream Multiply". Drag it in and connect it with Midi to Poly velocity.That's how you can multiply your signal. This component multiplies two Stream values together. :idea:
JC Conkato
rdgaudio
Postby musella » Thu Mar 16, 2017 3:13 pm
hello,
I've founded the solution !
musella
Postby musella » Fri Mar 17, 2017 8:57 am
Hello, thanks for your answer ! I'll try your option.
I've founded VCA module just before your answer... It works perfectly !
musella
Users browsing this forum: No registered users and 81 guests
