ifthenelse for arrays in ruby?
Re: ifthenelse for arrays in ruby?
Postby TheOm » Fri Jul 18, 2014 9:27 pm
What do you mean by ranges? It works for strings too:
Schematic1_new.fsm
(594 Bytes) Downloaded 963 times
TheOm
Postby tester » Fri Jul 18, 2014 9:46 pm
Thanks!
By ranges - let say that I'm not a good rubyist. :mrgreen:
Postby tester » Sat Jul 19, 2014 12:33 am
Small problem. If I change the input type from "string array" into "int array" - ruby module no longer works (empty ouptuts). Can this be fixed, so that there is no need to use text primitive between nodes?
Postby Tronic » Sat Jul 19, 2014 1:26 am
you mean this?
battle_tester_vs_ruby.fsm
(602 Bytes) Downloaded 997 times
Tronic
Postby tester » Sat Jul 19, 2014 1:56 am
Yes, thanks.
Postby RJHollins » Sat Jul 19, 2014 2:04 am
Tronic wrote:you mean this?
haven't checked the fsm ... but the file title gave a chuckle
:lol:
Postby tester » Sat Jul 19, 2014 2:35 am
It took me two minutes to realize the difference. Quotation marks. :-)
I'm in the middle of heavy brainstorming. Creating a cookbook according to TCM - yet another unusual application of FS. (yep, I hear these voices - definately with x64 cooking would be 2x faster :mrgreen:).
Postby tester » Tue Jul 29, 2014 11:58 pm
I have one more thing.
I'd like to convert one bigger array according to rules stored in two smaller arrays. Like this.
input array:
el1
el2
el3
el1
el3
contitions arrays ("=" separated to make it more readable; can be in two independent text files or like this):
el1=element1
el2=element2
el3=somethingelse
el4=andsomethingelsemore
output would be then like this:
element1
element2
element3
element1
element3
How?
Postby TheOm » Wed Jul 30, 2014 12:43 am
Combine your condition arrays into a Hash.
Then map the input array to the output using that Hash.
hash.fsm
(459 Bytes) Downloaded 982 times
TheOm
Postby tester » Wed Jul 30, 2014 5:15 pm
Thank you!
Users browsing this forum: No registered users and 46 guests
