Voice id example..?
Voice id example..?
No idea how to approach this new feature....
Checked its output....still confused. .
Can someone knock up a quick example, or
explain how to go about using it...and maybe
some rough ideas as to what can be done with it..
Thanks..
Thanks..
Re: Voice id example..?
Hey billv,
Check out my Free Running Poly Oscillators.
These rely on the channelID to work, basically with this you can identify each stream(channel) within the Poly section which means data can be written and read back to the correct channel. This just wasn't possible before so up until now neither was Free Runnning Oscs, now thankfully they are.
This is a big deal for synth builders now it is possible to create a proper analog sounding synth.
- Exo
Thanks Exo...
Thanks Exo.
Sounds great. Only wish fast bug fix in 3.05.
kortezzzz - Posts: 763
Users browsing this forum: No registered users and 42 guests
