better db to linear 0-1 (especially array)
most methods involve using code or asm and that's not as efficient as this. I was working ona metering solution for My boardstation EQ and came up with this, so as to avoid any zero's. It's as close as you can get to -INF
First, send the signal to a nan to 0 made by trog or exonerate, on the top value of the selector, add this value in a string:
next send that signal to an array limit module made by trogluddite.
Replace the min with the same value in a string:
so next make two floats with these two values:
and
and use all of it as follows
signal--->nan to 0 (edited)--->(0.00109043*signal)--------->(0.978191+signal)--------------> (final result 0-1)
this can be useful for just about anything. You could use it for floats also instead of arrays in a similar manner.
Robert
-897.06939697265625
-897.06939697265625
and
Robert
Re: better db to linear 0-1 (especially array)
That's an interesting approach, but in no way better than the usual
You're converting strings (this alone takes longer than above calculation), use two code blocks and still multiply and add. It's ok, but not better.
10^(n/20)
## or
10^(n * 0.05)
How's exp(0.115129254649702 * n) ?
- juha_tp
good feedback thanks, My goal however was to avoid the presence of a zero, other than in the case of a 0dBFS. So as to convert and utilize, which db conversion can miss.
