Double Gate?
Re: Double Gate?
Postby adamszabo » Wed May 20, 2020 5:41 pm
If you connect a "changed" module to the ruby bool out, it will only trigger when changed.
adamszabo
Re: Double Gate?
Postby tiffy » Wed May 20, 2020 10:37 pm
adamszabo wrote:If you connect a "changed" module to the ruby bool out, it will only trigger when changed.
Thank you adamszabo I will use it then as you recommended.
tiffy
Return to DSP
