Flowstone crashing
Flowstone crashing
Postby Flemming » Sat Aug 16, 2014 12:54 pm
My Flowstone crashes kinda often. I bet it's because my obscure wiring is far from ok, though it seems kinda random. Now finally i have a case where i'm able to reproduce the meltdown :twisted:
The attached schematic is my very first go at a simple Delay module. The module works, producing delay according to parameters and chosen delay type. To select the delay type i used a Selector dropdown module, and this is the heart of my booboo :cry: If i change the delay type a few times in a row (using the mouse clicking the dropdown) my Flowstone crashes. Sometimes it takes a good handful of changes, sometimes only a few. It happens even if there is no sound going through the delay.
Remeber that i am very new to Flowstone and you may find my schem to be kinda childish :lol: So, besides kicking me in the right direction towards a solution to my Selector problem, i am also very open to general input about good and bad practice in Flowstone.
Delay.fsm
Crashing delay
(23.08 KiB) Downloaded 1006 times
Flemming
Re: Flowstone crashing
Postby Nubeat7 » Sat Aug 16, 2014 8:08 pm
hmm, thats a good question, your schematic should be fine, it seems that this is related to this bug
viewtopic.php?f=2&t=2674&start=40
this looks like that the bug is related to selectors and asio, because the schematic works if you choose not an asio audiodriver!
Postby Nubeat7 » Sat Aug 16, 2014 8:13 pm
i tried to just put 2 selectors in series and the same happens!
edit: it seems that it also happens with generic lowlatency driver but not that often!
audioselector bug.fsm
(24 KiB) Downloaded 1027 times
Postby Flemming » Sat Aug 16, 2014 8:49 pm
Aw, bugger :( anyways, thanks for checking my schem out. I'm glad it looks normal.
Too bad about the bug, but it seems from the other thread that it already has been reported.. og should i do something active to let the grownups know that we found a 'dead squirel in the sandbox'??
Thank you very much for your feedback, Nubeat7.
I actually like this forum a lot. I'm proud to have become a 'stoner' :lol:
Flemming
Postby KG_is_back » Sat Aug 16, 2014 9:21 pm
You may use code block to "mimic" a selector/multiplexer. Usually Selectors also bypass the sections that are turned off (So the don't process = don't waste CPU), but in this particular schematic it makes no difference, so there shouldn't be any significant CPU waste at all.
//Multiplexer
streamin Select;
streamin in;
streamout out0;
streamout out1;
streamout out2;
out0=in&(Select==0);
out1=in&(Select==1);
out2=in&(Select==2);
KG_is_back
Postby Exo » Sat Aug 16, 2014 10:42 pm
Flemming wrote:Aw, bugger :( anyways, thanks for checking my schem out. I'm glad it looks normal.
I would still pass it on, just email support.
Exo
Postby Flemming » Sun Aug 17, 2014 12:14 am
Exo wrote:I would still pass it on, just email support.
You're right. I sent them an email with links to here and the other thread.
Flemming
Postby Flemming » Sun Aug 17, 2014 1:21 am
KG_is_back wrote:You may use code block to "mimic" a selector/multiplexer. Usually Selectors also bypass the sections that are turned off (So the don't process = don't waste CPU), but in this particular schematic it makes no difference, so there shouldn't be any significant CPU waste at all.
//Multiplexer
streamin Select;
streamin in;
streamout out0;
streamout out1;
streamout out2;
I copied your code and used it to replace the Multiplexer primitives. Then i started clicking that Selector dropdown like i was all out of coffee - no crashing yet. I'll have to catch some sleep now, but i'll make sure to click some more tomorrow..... just to be sure :D
Thank you very much for this solution!
Flemming
Postby Flemming » Sun Aug 17, 2014 12:06 pm
Nubeat7 wrote:i tried to just put 2 selectors in series and the same happens!
Your Selector example crashes here for me also. I play a few notes and then click the Selector a few times, i get a crash.
So i guess that both the Multiplex and Selector primitives are affected by this bug :?
Flemming
Postby KG_is_back » Sun Aug 17, 2014 12:56 pm
I tried both Flemming's and Nubeat7's example schematic and they work completely flawlessly in Flowstone 3.0.2 Firefly free version - never had a single crash even after several dozen tries. So the bug must've been introduced after that update.
KG_is_back
