Concatenate Arrays
Concatenate Arrays
As the title says, this puts arrays in one big array. Modules for concatenation as well as reading separate sub-arrays back in are provided.
This demonstration version uses the preset parameter array for concatenation, but you can easily change this by replacing that prim with a normal array prim.
It can be useful if you want to save arrays for whatever reason.
multi_arrays_to_one_preset.fsm- (3.52 KiB) Downloaded 1098 times
Re: Concatenate Arrays
Will definately check this out ! Always working arrays
Thanks tulamide
Thanks tulamide
You're welcome
And thank you very much for the comment!
