FIR filter
FIR filter
Postby lizard4mg » Mon Jun 11, 2012 12:49 pm
I want to process the convolution of an audio input signal with an impulse response. How can I create a FIR filter? Can I introduced the coefficients by using a text file?
Thanks!
lizard4mg
Re: FIR filter
Postby Embedded » Sun Jun 24, 2012 6:00 am
If you want to make your own filter then you can use the DSP code component.
If you look inside something like the Moog Filter you will see the DSP code component used at the bottom level.
Embedded
Re: FIR filter
Postby VPDannyMan » Thu Dec 27, 2012 8:08 pm
MYCO released a convolver quite a while ago on the SM forum.. I didn't see it available here yet so check the sm forum search for MYCO and real time convolution.
edit:
It might have been matti that did that convolver?
VPDannyMan
Re: FIR filter
Postby matti » Fri Mar 01, 2013 11:25 pm
VPDannyMan wrote:MYCO released a convolver quite a while ago on the SM forum.. I didn't see it available here yet so check the sm forum search for MYCO and real time convolution.
edit:
Yep, me. Hi :D
Though it seems the files haven't been online for a while now. I'll have to see if i have them somewhere.
Edit: I read through the original thread from SM forums (as i don't remember where it was left) and i think it might not be a very good example for FS. If i rewrote it with FS specific tricks it might work better. Maybe a project for some rainy day :D
matti
Re: FIR filter
Postby VPDannyMan » Wed Mar 06, 2013 5:52 pm
yes..
VPDannyMan
Return to DSP
Users browsing this forum: No registered users and 80 guests
