RUBY Encoding format
Re: RUBY Encoding format
Postby JB_AU » Mon Aug 18, 2014 10:57 am
Silly me :oops: I just remembered the inbox files are "plain text" , you should be able to work directly with them.
Albert Einstein
JB_AU
Postby Walter Sommerfeld » Sat Aug 23, 2014 4:40 pm
Encoding: (in method 'event')::ConverterNotFoundError: code converter not found (ASCII-8BIT to UTF-8)
have this prob in my actual ruby file finder:
#Encoding.name_list
#=> ["ASCII-8BIT", "UTF-8", "US-ASCII". "external", "filesystem"]
Encoding.default_external = "UTF-8" if defined? Encoding
...code
Reason: Filename has a "-" with ascii code 150 instead of 45... :(
Will i have to change all the filenames or is there a workaround???
Walter
Walter Sommerfeld
