make a 7 band eq or better splitter
Postby CoreStylerz » Sun Sep 21, 2014 6:27 pm
There was a good freq. Splitter in sybthmaker wiki. But it was limited by 3 bands..
I would like to make a splitter like that but with more bands (7) or make a simple eq.
What's best practice for make stuff like that? Where to get started?
I've had a look to the eq cookbook, but ive not understand so much of it.
Any hint?
BTW.
It correct this?
To make an eq I need to separate (calculate) each band and then process filters like LP, HP, peak?
PM me if you are interested.
CoreStylerz
Re: make a 7 band eq or better splitter
Postby martinvicanek » Sun Sep 21, 2014 8:58 pm
Here is a 7 band splitter
viewtopic.php?f=4&t=2236#p10448
However, if you are after an EQ I'd suggest using peaking filters instead.
Postby Youlean » Tue Oct 07, 2014 12:37 pm
Hi, I have looked at the paper you provided for making three structure filters, but I was not able to understand it... Could you please explain how to calculate where to put allpass filters? I even tried to build 12 band splitter provided inside paper, but for some reason it didn't work well (I had phasing issues)...
Youlean
Postby martinvicanek » Wed Oct 08, 2014 10:12 am
Yes, the math notation in that paper is a bit formal. :mrgreen: I'll try to put together a (hopefully easier to digest) tutorial later.
Postby Youlean » Wed Oct 08, 2014 2:22 pm
martinvicanek wrote:Yes, the math notation in that paper is a bit formal. :mrgreen: I'll try to put together a (hopefully easier to digest) tutorial later.
Thanks a lot! This could be very useful for others also...
Youlean
Multi-Band Splitter Tutorial
Postby martinvicanek » Thu Oct 09, 2014 10:01 pm
Okay, here is my multi-band splitter tutorial. Please give me your feedback so I can improve it and put it up on FS Guru. ;)
MultiBandSplitterTutorial.fsm
(88.24 KiB) Downloaded 1195 times
Postby KG_is_back » Thu Oct 09, 2014 10:31 pm
wow martin this is great! ...maybe adding phase/magnitude switch to the analyzer?
KG_is_back
Postby RJHollins » Fri Oct 10, 2014 12:22 am
We love it when you do stuff like this !!!
Thanks Martin :D
Postby Walter Sommerfeld » Fri Oct 10, 2014 5:24 pm
Many thanks from me 2 Martin !!!
You are our new 'teacher' :)
keep on doing!
Walter
Walter Sommerfeld
Postby Exo » Fri Oct 10, 2014 6:02 pm
Thanks Martin great work :)
I have a nice multi band splitter GUI (not my old wiki one) I was going to share on FS Guru I might update the audio part to use this ;)
Exo
