minor DSP question
minor DSP question
Postby Rocko » Tue Oct 14, 2014 4:52 pm
I'm trying to convert some SYSEX data which originates from an old synthesizer and saved on PC as txt file.
This is like a backup system for vintage synths, instead of magnetic cassettes which were popular at the eighties...
The data on PC appears like this (txt):
F0xxxxxxxxxF7zz
F0xxxxxxxxxF7zz
F0xxxxxxxxxF7zz
F0xxxxxxxxxF7zz
F0xxxxxxxxxF7zz
Each line starts with F0, then data, then F7 and a unique 'zz' followed by '/n' (next line) as text document.
F0 and F7 are not unique but must appear at start and end of line.
Is there a way I can convert this file from 'string' to 'string array' in fast mode?
I thought of building a 'logic module' which will find the 'zz' at each line, push it into a stack (or array) and go for the next line, but I might be missing something a bit more basic.
Is there a more elegant way to break such a file from 'string' to 'string array'? Using green math? Using RUBY? using code? Maybe a 'string to string array' module based on new lines ('/n') ??
Thanks,
Rocko
Rocko
Re: minor DSP question
Postby Exo » Tue Oct 14, 2014 5:24 pm
Hey Rocko,
Load the text file with the load text primitive and connect to its output a "Text" Component, now connected this text component to the array input on the String array, now it should contain each line as an index in the array.
Exo
Postby Rocko » Tue Oct 14, 2014 6:17 pm
Thanks.
I simply sent the output of the text file into an input of "string array append" and then sorted it.
Thank you !
Rocko
Rocko
Postby Rocko » Tue Oct 14, 2014 6:27 pm
Is there a way to determine the array size, i.e. the number of lines in the txt file?
Edit:
Founjd a way, just connect the output of 'text' to input of 'string array append' (nothing appended).
Then connect the output to 'string array append' to 'int' to see the size.
Rocko
Return to DSP
