How do i set Moog Octave?
i see it has WIDE,32,16,8,4,2 How do i set this octave help pls
- djbrynte
Re: How do i set Moog Octave?
Not sure perhaps its similar to the ones I've seen ones that go 8,16,32,64,LOW which selects it as a LFO and the fine tune then becomes the speed control.
- Xtinct
im not sure.
I just wana set the octave knob the same. As the octave knob on Moog. Its for My synth vaccin. Like how many steps etc like that.
- djbrynte
Well if you ignore the wide/low setting you already have it 32 to 2 is a 4 octave shift and I see from your pic you have a knob that goes from -24 to +24 I assume its semitones and therefore is a four octave range
- Xtinct
how you mean sry my dyslexia fucks it up. Would be great if you make a simple module or something with 1 octave knob. SHowing how it should be set up 32 16 8 4 2 thing.
- djbrynte
You already have it your knob that goes from-24 to +24 if its semitones then when set at -24 = 32, set at -12 = 16,
set at 0 = 8, set at +12 = 4 and set at +24 = 2 if this is not clear then post up your knob and I will change it for you.
- Xtinct
Users browsing this forum: No registered users and 78 guests
