Ruby Issue: Draw and Init
• Page 2 of 2 • 1, 2
Re: Ruby Issue: Draw and Init
wrong you again too,
when you trig every input, the module is re-evaluate,
only variable there is into the event method respect the directive of trig event.
- Tronic
Tronic wrote:wrong you again too,
I'm not sure, what you're saying here. One thing's for sure, values don't just disappear because of the 'event' method being executed. However, I took you serious enough to stay at the issue, but everything I do proves me right. Here's another example.
Tell me what number is drawn when you open the schematic. Then enter a space or a new line in the editor and tell me what number you then see. Oh, and feel free to trigger the 'event' method as often as you like.
But I'm sure you will find a way to explain it such, that I am wrong, right?
order_issue 3.fsm- (551 Bytes) Downloaded 704 times
