FlowStone 3.0.6 PEBBLE
Postby tester » Mon Nov 03, 2014 11:04 pm
...is ready to download :mrgreen:
Re: FlowStone 3.0.6 PEBBLE
Postby Exo » Mon Nov 03, 2014 11:28 pm
I've done a quick Review :)
Exo
Postby tester » Tue Nov 04, 2014 12:06 am
But there is something wrong with this new indexer. From what I see - it picks "last" index in reversed order. Or am I missing something?
indexer.fsm
(370 Bytes) Downloaded 1036 times
Postby Attic » Tue Nov 04, 2014 12:57 am
It seems to be down to wiring order . Notice it seems to always use the wire that was connected first as it traverses the schematic.
indexer Shortest path.fsm
(634 Bytes) Downloaded 1047 times
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Attic
Postby tester » Tue Nov 04, 2014 1:31 am
Yes I see it, but this is still reversed order.
indexer-trigger-order.fsm
(447 Bytes) Downloaded 1046 times
Postby Nubeat7 » Tue Nov 04, 2014 12:43 pm
is there no way anymore to move into modules from the mainview?
there is this new feature to select the different views in the main window, before 3.05 it was possible to move into modules with a doubleclick, but now this isn't possible anymore, i mean its nice to select all viewlevels from the mainview but maybe an option in the rightclick menu to move over there would be really helpful, now i always need to dive down level for level and often in complex projects its diffcult to find what you are looking for...
Postby djbrynte » Tue Nov 04, 2014 2:02 pm
ye i know i also tested this version. And get same problem with this as nubeat talking about. was a hell of work to do it this way. No option to go inside the synth.
djbrynte
Postby tester » Tue Nov 04, 2014 3:06 pm
Nubeat7 wrote:is there no way anymore to move into modules from the mainview?
This one is real PITA. Is there any other key shortcut to perform that "go to selected" operation? Actually what happens right now when you double click on gui parts in edit mode? They become inactive here.
Postby Nubeat7 » Tue Nov 04, 2014 3:26 pm
the good thing is that you can place and resize all gui elements also when they are nested, that means you can select, place and resize all view levels from tha main view what you couldn't do before, but you cannot switch to the selected module what was done with the doubleclick before, all in all this is a good feature and makes gui organisation much easier, but sadly for the cost of directly jumping into the selected module.. or did i miss something?
Postby Exo » Tue Nov 04, 2014 3:33 pm
Nubeat7 wrote:the good thing is that you can place and resize all gui elements also when they are nested, that means you can select, place and resize all view levels from tha main view what you couldn't do before, but you cannot switch to the selected module what was done with the doubleclick before, all in all this is a good feature and makes gui organisation much easier, but sadly for the cost of directly jumping into the selected module.. or did i miss something?
It is much better now for arranging the GUI. But no it looks like the old 'feature' is gone, I bet Malc thought no one would miss that. I guess jumping to the module can still be useful.
Exo
