FlowStone 3.0.8 SKYLARK(any bugs or issues)
Postby tester » Tue Nov 04, 2014 12:18 am
FlowStone 3.0.8 SKYLARK - list of bugs and issues (starts on page 4).
If I may suggest something useful.
1) If you find any bugs or issues - post them here as a reference description and...
2) If you wish to discuss them (or just for further discussion) - open new topic with it, and...
3) In reference description below - add link to opened topic on that problem.
* also, if there are other unindexed problems discussed in separate topics - it will be good to keep track on them and place here too.
I would also suggest (Exo?)
4) to make this post sticky until next release.
With last 305 release - I (and as far I remember - not only me) had really big problems with finding and remembering details on what isn't working there correctly and to what degree. This approach should clarify things a little bit.
Re: FlowStone 3.0.6 PEBBLE - list of bugs and issues
Postby tester » Tue Nov 04, 2014 12:20 am
Example of problem pointed somewhere but not discussed separately.
viewtopic.php?f=2&t=2938#p15985
The new indexer primitive seems to detect triggers / pick "last" indexes in reversed order.
Postby djbrynte » Tue Nov 04, 2014 7:23 am
Great tester!
djbrynte
Postby Exo » Tue Nov 04, 2014 8:22 am
Good idea :) I don't have the ability to make this a sticky though.
Exo
Postby Nubeat7 » Tue Nov 04, 2014 8:26 am
good idea tester, thanks!
Postby tester » Tue Nov 04, 2014 10:42 am
I sent request to Malc to make sticky this one. If you as a moderator can edit content or remove posts, then the topic could be re-edited per release, to keep tracking on what is going on.
Re: FlowStone 3.0.6 PEBBLE (any bugs or issues)
Postby Nubeat7 » Sun Nov 09, 2014 1:19 pm
just got some strange issue in the serach mod/prim part, if no tag is selected and i type in "ke" flowstone crashes!?
anyone else has this issue?
Postby nix » Sun Nov 09, 2014 9:55 pm
Nope, it doesn't crash here with 'ke'
I had all prims except bus create vanish form the toolbox though-
I had to copy/paste the project to get them back.
It wasn't that I had a search and and any tags selected,
IMO it was a bug
nix
Postby Nubeat7 » Sun Nov 09, 2014 10:33 pm
hmm, i just copied all the tags into the FS folder when changing to the new computer, this worked pretty well, but there is this search thing.. maybe i should clean up one day..
Postby tester » Thu Nov 20, 2014 3:01 am
Is there a problem with ruby component between 304 and 306? I'm getting errors on all ruby windows in my schematic after update, and I can't get rid of it. After "clearing" the bug, and exporting app - things get red again. I don't know, maybe some inputs are stored somewhere between "sample and holds".
...but I can load such re-saved schematic on older FS and without issues. :-/
