old BUG: don't trust the De-Threader
Postby Walter Sommerfeld » Thu Nov 27, 2014 12:10 pm
i ignored 66 month's ago aliasants info here:
MIDI compatible timer:
http://synthmaker.co.uk/forum/viewtopic.php?f=7&t=4608&start=0&st=0&sk=t&sd=a&hilit=midi+compatible+timer
see External MIDI data on same process:
http://synthmaker.co.uk/forum/viewtopic.php?f=12&t=9724&start=0&st=0&sk=t&sd=a&hilit=Using+timers+with+MIDI
based on "Using timers with MID"I:
http://synthmaker.co.uk/forum/viewtopic.php?f=7&t=3673&start=0&st=0&sk=t&sd=a
I recovered an old project: MidiTrak Merger with only 25 Led's to show Midi action...
until now these Led's goes crazy after some time of hammering Midi Split triggers into them :(
some like to be dark some others lights always :twisted:
I only touched this project again because Luddite gave us his ruby Midi Analyser some times before and it reminded me that i had one of my own wo ruby which crashes when 2 much data arrived...
P.S.: Is there a way in ruby to overcome this w/o firing always triggers (on a Bool OUT)???
here what i found after some digging into the De-Threader:
De-Threader Off wo reason.png (100.92 KiB) Viewed 9208 times
De-Threader ON wo reason inside Modul why Intsw TRUE.png (94.92 KiB) Viewed 9208 times
Walter Sommerfeld
Users browsing this forum: No registered users and 39 guests
