Advanced DSP Question
Postby Youlean » Tue Dec 09, 2014 8:30 pm
Hey guys, is there any way to count how many samples is audio being above 0, and to place that information before >0 occurs with delaying original audio?
Youlean
Re: Advanced DSP Question
Postby tester » Tue Dec 09, 2014 10:54 pm
+1
Would be interesting to be able to count in parallel (sample accurate) amounts of samples within specified min/max ranges. [output can be float type and not integer type, because calculations made on that are rather approximations).
Postby KG_is_back » Wed Dec 10, 2014 12:01 am
I'm not exactly sure what you are trying to do... With the counting samples, the thing is fairly simple:
streamin in;
streamout out;
float c;
float above;
float pin;
above=(in>0)&(pin<=0);
out=out+(c-out)&above;
c=c+1-c&above;
With the delaying, I'm not sure what you are looking for...
KG_is_back
Postby Youlean » Wed Dec 10, 2014 12:33 am
Look at the picture. I could post a FSM if you need it, but it is very messy...
Basically I want to calculate cycle length and to have that information right before cycle occurs, so I can set accurate release, independent for every cycle in envelope follower.
Logic is to:
audio -> fixed delay
audio -> sample counter -> variable delay(fixed delay - cycle length)
Youlean
Postby tester » Wed Dec 10, 2014 12:36 am
As for me, I still don't know what I'm doing. ;-) Yesterday an idea came to me, and I'm trying to figure out what is it about. Probably some sort of a measurement within a filter-like something.
The concept is.
Audio resolution is n bits (but this is related to signals in general and some statistical calculations). I'd like to measure how many sample-to-sample differences fit bit ranges (1bit range ~ 0-6dB, 2bit range ~ 6-12dB, etc), and compare these outcomes to each other.
I'm still not sure what for this is useful, but I find it... intriguing. Maybe it may be helpful somehow to describe audio true dynamics of a compressed/pumped signal? Or level of subtleness in details? I don't know yet. :mrgreen:
Postby Youlean » Wed Dec 10, 2014 12:43 am
What do you mean by sample to sample differences?
Youlean
Postby KG_is_back » Wed Dec 10, 2014 12:53 am
As you suggest All you have to do, is to put constant delay on original audio. Detect the positive pulse length from the original (non-delayed) input. The event you want to happen should occur at constant delay minus detected length. That is the amount of time you need to delay the "side-chain" input, if you wish so. The delay will be modulated in a jump fashion but that shouldn't be a problem.
KG_is_back
Postby tester » Wed Dec 10, 2014 11:25 am
Youlean wrote:What do you mean by sample to sample differences?
(sampleN) minus (sampleN+1). In short terms - gain differences between samples. Following curiosity - I'd like to see - how much fluctuations are going on in dynamic ranges defined by bits (or 6dB steps). And then - I'd like to hear what it means in audible terms.
Postby Youlean » Wed Dec 10, 2014 4:46 pm
KG_is_back wrote:As you suggest All you have to do, is to put constant delay on original audio. Detect the positive pulse length from the original (non-delayed) input. The event you want to happen should occur at constant delay minus detected length. That is the amount of time you need to delay the "side-chain" input, if you wish so. The delay will be modulated in a jump fashion but that shouldn't be a problem.
Indeed, there where some bug in my schematics, but now it seams to work...
Youlean
Postby Youlean » Wed Dec 10, 2014 4:47 pm
Well test it and see what it will do... :)
Youlean
Return to DSP
