Math help
Math help
Postby adamszabo » Wed Sep 16, 2020 3:42 pm
Hey friends,
I have to revisit an old code with this nasty formula: 0.0001^( SampleRate / ( 10^(( x-1)*4.307) - 4.925e-005 )*600 ), and I have to rewrite this in stream form, which will use way too much CPU because there are too many powers and a division. Are there any math wizards that can help me rewrite this in a much simpler form? It doesnt matter if there are some errors, as long as its close to it. The only variable is the 'x' and a samplerate input.
Thank you!
formula.fsm
(254.63 KiB) Downloaded 1016 times
adamszabo
Re: Math help
Postby aronb » Wed Sep 16, 2020 6:22 pm
I might be able to help... BUT I have a few questions:
1) What are you calculating? Might be a more efficient way...
2) Otherwise is it just that EXACT formula?
3) What tolerances do you need? How exact does what you are calculating have to be...
Thank you,
Aron
aronb
Re: Math help
Postby juha_tp » Wed Sep 16, 2020 6:25 pm
Try Simplify[0.0001^( f / ( 10^(( x-1)*4.307) - 4.925e-005 )*600 )] at https://www.wolframalpha.com/
juha_tp
Re: Math help
Postby MichaelBenjamin » Wed Sep 16, 2020 7:00 pm
Last edited by MichaelBenjamin on Mon Sep 21, 2020 11:02 am, edited 1 time in total.
MichaelBenjamin
Re: Math help
Postby juha_tp » Wed Sep 16, 2020 7:08 pm
What is the range for variable "x" ?
juha_tp
Re: Math help
Postby adamszabo » Wed Sep 16, 2020 8:18 pm
Thanks guys. This is for a decay calculation on my envelope so it needs to be pretty accurate, but it depends on the formula on how much cpu I can save. The range for the x input is from 0-1 only.
adamszabo
Re: Math help
Postby martinvicanek » Wed Sep 16, 2020 8:36 pm
The formula that is implemented in the schematic should read
0.0001^{1/[600*SampleRate*(10^4.307*(x - 1) - 4.925e-5)]}
For x in the range between 0 and 1, a reasonable approximation for 44.1k is
1 - (0.9939 + 2914*x)/(1 + x*(3102 + x*4356980))
Relative error is less than 1%.
Re: Math help
Postby adamszabo » Wed Sep 16, 2020 8:52 pm
Thanks Martin!
The sample rate variable must be dynamic however, as the synth will get the samerate from the DAW. I cannot set it as fixed. Any ideas what to do in that case?
adamszabo
Re: Math help
Postby deraudrl » Wed Sep 16, 2020 9:50 pm
adamszabo wrote:Thanks Martin!
Derive the constants in Martin's equation once when the sample rate changes, then use the simplified equation thereafter?
Or maybe just look them up from a table: I suspect the number of different values for sample rate that you need to be able to deal with is rather small.
deraudrl
Re: Math help
Postby martinvicanek » Thu Sep 17, 2020 8:25 am
Forget my previous post. If the quantity of interest is the decay factor per sample, you need much more accuracy. I can offer the attached implementation using fast powers.
stream_formula.fsm
(121.88 KiB) Downloaded 1024 times
