Oversampling Toolkit (Revisited)
Re: Oversampling Toolkit (Revisited)
Postby MyCo » Sun Dec 21, 2014 8:42 pm
Jesus... how couldn't I see that. It would definetely make a difference on higher order version. On the Order 12 version it would save 12 multiplication each for up/downsampling.
Postby adamszabo » Sun Dec 21, 2014 9:03 pm
can you guys show what you mean with this optimization? :) how does the "order 2" look like now?
adamszabo
Postby MyCo » Sun Dec 21, 2014 9:35 pm
I'll make an update. It'll take a bit, because there are 24 modules to do it on :mrgreen:
Postby MyCo » Mon Dec 22, 2014 1:29 am
OK, I've updated the download in the first post with the changes Martin suggested. In the Order 10 Version it saves about 30 cycles according to the analyzer. That's pretty huge! On the decimator test it makes a difference of 0.2% according to FlowStones status bar.
Postby Tronic » Mon Dec 22, 2014 5:10 am
great work :)
one question, how you have calculated the coefficient for this HBAP ?
Tronic
Postby MyCo » Mon Dec 22, 2014 10:19 am
They are from this file:
http://musicdsp.org/files/BandLimit.cpp
Not sure how those coeffs were generated, may be that guy built them as lowpass first and splitted them later into allpasses. I've done the inverse of that, by just merging the paralleled allpasses together, as a first try.
They phase rotate 180° at fs/4 but each with different slope. That's all that I found out.
I used my filter construction kit, to get the cascaded filter coeffs from the biquads.
viewtopic.php?f=3&t=1234
Postby martinvicanek » Mon Dec 22, 2014 11:43 am
I think the theory is very well outlined in Tapio Saramäki's lecture notes, especially pages 12 and 28. You would use Matlab to get the coefficients.
Postby MyCo » Mon Dec 22, 2014 1:58 pm
yeah, but the art is: Choose the filter coeffs so that the upper half band ripples are as low as possible. Designing 2 Allpass in a Lowpass arrangment isn't a big deal. Designing 12 Lowpasses so that 1 half band is nearly unaffected and the other half gets as much reduced as possible, that's the difficult part.
Postby martinvicanek » Mon Dec 22, 2014 3:41 pm
Exactly!
Postby Tronic » Mon Dec 22, 2014 5:08 pm
Ok here the Polyphase IIR filter coefficient calculator :twisted:
# Ruby port of  http://ldesoras.free.fr/prod.html#src_hiir
# Troniclabs - 2014 #
# removed
Tronic
Return to DSP
