anyone know an optimized reverb?
Postby djbrynte » Mon Feb 02, 2015 7:50 pm
if u know any optimized reverb on synthmaker or flowstone let me know or if u have one u wana share pls.
djbrynte
Re: anyone know an optimized reverb?
Postby martinvicanek » Tue Feb 03, 2015 10:52 pm
This is what I have. Uses 30% CPU compared to the stock reverb.
FreeVerb_optimized.fsm
(19.4 KiB) Downloaded 906 times
Postby djbrynte » Wed Feb 04, 2015 1:51 am
awesome!
djbrynte
Postby Youlean » Wed Feb 04, 2015 1:06 pm
Here is the version that uses MyCo optimized delay. Now reverb have 50% less CPU usage than Martins...
KG is Back has some insanely optimized delays, maybe some could try his...
FreeVerb_optimized MyCo Delay.fsm
(20.45 KiB) Downloaded 901 times
Youlean
Postby djbrynte » Wed Feb 04, 2015 2:07 pm
nice bro but martins effect is a reverb and yours is a delay :P But thanx alot. You guys on Flostowne are the best! i mean i havent got this help somewhere else! BIG + to you guys!
SRY I SEE TRHIS IS REVERB TO! Nice done myco! maik:D
djbrynte
Postby djbrynte » Wed Feb 04, 2015 7:09 pm
Must say martins reverb used 2% lesser cpu :)
djbrynte
Postby djbrynte » Wed Feb 04, 2015 7:30 pm
is there an optimized delay aswell who use very very little cpu?
djbrynte
Postby KG_is_back » Wed Feb 04, 2015 8:14 pm
you may try these delays: http://flowstone.guru/downloads/efficient-delays-and-delay-code-generators/
currently only integer-length delays are supported, but interpolated versions are being worked on. I may finish them tomorrow and post them, if you're interested.
KG_is_back
Postby RJHollins » Wed Feb 04, 2015 8:32 pm
Hi KG,
Always interesting in your posting, be it code or discussion.
THANKS ! 8-)
Postby djbrynte » Wed Feb 04, 2015 8:48 pm
thnx will try those. But do i just put the asm code inside the stock delay?
djbrynte
