Restricting input in edit box?
Can someone tell me if there is an easy way to limit the amount of characters entered into an edit box? And if so, can there also be a distinction between only accepting numerical vs alphabetical characters?
Subquantum - Posts: 24
Re: Restricting input in edit box?
Hi
Here is an example of restriction by blocking the output and send a trigger to start if it exceeds the limitations. You can find the restrictions in the module properties.
Restricted Edit Box.fsm- (1.35 KiB) Downloaded 686 times
Mo - Posts: 17
Thanks Mo!
Looking at these examples really helps me to learn how to work with these graphical components beyond what is available in the manual.
