Restricting input in edit box?
Postby Subquantum » Fri Feb 06, 2015 4:08 pm
Can someone tell me if there is an easy way to limit the amount of characters entered into an edit box? And if so, can there also be a distinction between only accepting numerical vs alphabetical characters?
Subquantum
Re: Restricting input in edit box?
Postby Mo » Sat Feb 07, 2015 7:14 am
Hi
Here is an example of restriction by blocking the output and send a trigger to start if it exceeds the limitations. You can find the restrictions in the module properties.
Restricted Edit Box.fsm
(1.35 KiB) Downloaded 686 times
Mo
Postby Subquantum » Mon Feb 09, 2015 2:46 pm
Thanks Mo!
Looking at these examples really helps me to learn how to work with these graphical components beyond what is available in the manual.
Subquantum
