Poly Slicer V1.0 Alpha
Re: Poly Slicer V1.0 Alpha
Postby Youlean » Tue Mar 17, 2015 10:50 pm
Hi Exo, where can I hind dll for your Poly Slicer?
Youlean
Postby Exo » Tue Mar 17, 2015 10:59 pm
It is saved inside the dll component. If you want to use it yourself just copy and paste it.
The actual code for the dll is HERE
Exo
Postby Youlean » Tue Mar 17, 2015 11:10 pm
Hm, well for some reason I can't load wav, or mp3 files. Here is screenshot inside wav file module...
dll problem.jpg (84.62 KiB) Viewed 17078 times
Youlean
Postby Youlean » Tue Mar 17, 2015 11:13 pm
And here it shows the name of loaded wav file, but it will not load the mp3...
Youlean
Postby Exo » Tue Mar 17, 2015 11:20 pm
Well here is the dll...
libFlowstoneAudioFiles.zip
(280.77 KiB) Downloaded 1163 times
Also mp3 is not supported in this dll.
I posted an mp3 to wav module HERE but I offer no support at all for that. It converts mp3 to wav but saves the created wav to the hard drive which is never deleted...
Exo
Postby Youlean » Tue Mar 17, 2015 11:24 pm
Ok, thanks. It works now. BTW, thanks for the huge work making this.. ;)
Youlean
Postby Exo » Tue Mar 17, 2015 11:28 pm
Youlean wrote:Ok, thanks. It works now. BTW, thanks for the huge work making this.. ;)
Thanks, the scroll and zoom display is something I always wanted to do in Flowstone but it was never possible (too inefficient), until the dll component that is :)
Exo
