can some one help me with an assembler code? simple one
I wana add a pulse to the main line. Now i have 2 osc and i wana add a pulse to one of the osc.
SO basicly when i raise the volume of the pulse the main signal should take off. SO when its 50/50 there should be normal osc and the pulse one.
ANd when pulse is full there should only be a pulse there
so basicly i need to add 2 lines and 1 out for the control.
So its some mathematics. Like
in1 = main osc
in2 = pulse osc
in3 = pulse volume
And they should work like if u raise the volume of 1 the other should take off.
Duno what i need also i dont know if this affect the mixer volume?
in1 = main osc
in2 = pulse osc
in3 = pulse volume
- djbrynte
Re: can some one help me with an assembler code? simple one
streamin in1;
streamin in2;
streamin in3;
streamout out;
out=in1*in3+in2*(1-in3);
which also can be written as:
out=in3*(in1-in2)+in2;
assembler optimized version:
streamin in1;
streamin in2;
streamin in3;
streamout out;
movaps xmm0,in2;
movaps xmm1,in1;
subps xmm1,xmm0;
mulps xmm1,in3;
addps xmm1,xmm0;
movaps out,xmm1;
nice thank you il test it.
- djbrynte
The code isent working. I tested the optimized version. it doesent work at all.
- djbrynte
sry it worked it was just diffrent ways lol
1 is 2 instead.
- djbrynte
if i wana add a line in for Matrix LFO or ENV to Pulse how do i do it?
- djbrynte
