can some one help me with an assembler code? simple one
Postby djbrynte » Thu Mar 19, 2015 1:02 pm
I wana add a pulse to the main line. Now i have 2 osc and i wana add a pulse to one of the osc.
SO basicly when i raise the volume of the pulse the main signal should take off. SO when its 50/50 there should be normal osc and the pulse one.
ANd when pulse is full there should only be a pulse there :)
so basicly i need to add 2 lines and 1 out for the control.
So its some mathematics. Like
in1 = main osc
in2 = pulse osc
in3 = pulse volume
And they should work like if u raise the volume of 1 the other should take off.
Duno what i need also i dont know if this affect the mixer volume?
djbrynte
Re: can some one help me with an assembler code? simple one
Postby KG_is_back » Thu Mar 19, 2015 3:40 pm
streamin in1;
streamin in2;
streamin in3;
streamout out;
out=in1*in3+in2*(1-in3);
which also can be written as:
out=in3*(in1-in2)+in2;
assembler optimized version:
streamin in1;
streamin in2;
streamin in3;
streamout out;
movaps xmm0,in2;
movaps xmm1,in1;
subps xmm1,xmm0;
mulps xmm1,in3;
addps xmm1,xmm0;
movaps out,xmm1;
KG_is_back
Postby djbrynte » Thu Mar 19, 2015 3:48 pm
nice thank you il test it.
djbrynte
Postby djbrynte » Thu Mar 19, 2015 9:23 pm
The code isent working. I tested the optimized version. it doesent work at all.
djbrynte
Postby djbrynte » Thu Mar 19, 2015 9:26 pm
sry it worked it was just diffrent ways lol :P 1 is 2 instead.
djbrynte
Postby djbrynte » Thu Mar 19, 2015 11:00 pm
if i wana add a line in for Matrix LFO or ENV to Pulse how do i do it?
djbrynte
Postby djbrynte » Fri Mar 20, 2015 2:26 pm
no one?
djbrynte
