FS crashes at start, reinstall doesn't help
Postby martinvicanek » Sat Mar 21, 2015 10:16 pm
Wow, this bug is sticky. After a crash Flowstone will not start whatsoever. Not after Windows restart. Not after reinstall. Not after uninstall and reinstall. :shock: :evil:
Any hints?
Re: FS crashes at start, reinstall doesn't help
Postby Jay » Sat Mar 21, 2015 10:25 pm
Hiya
You could try removing your user modules folder from wherever you have it atm and see if it loads m8, it might be something in there that is stopping it from loading, ive had similar issues before and ended up having to rebuild my entire toolbox :(
hope you get fixed out :)
Jay
Postby martinvicanek » Sat Mar 21, 2015 11:32 pm
Jay wrote:Hiya
Many thanks, Jay. Didn't help though :cry:. Must be something else offending FS.
Also Malc's suggestion to delete HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone didn't help either.
Any hint (other than format c: ;) )?
Postby MyCo » Sun Mar 22, 2015 12:05 am
Most likely there is something wrong with your user data. Maybe a recovery schematic or broken modules in the toolbox. Try temporarly renaming that folder so that FS can't find it anymore:
%appdata%\FlowStone
Postby KG_is_back » Sun Mar 22, 2015 12:29 am
I had similar problem quite some time ago. Try to delete Flowstone in Registry, using Registry Editor. It worked for me.
KG_is_back
Postby martinvicanek » Sun Mar 22, 2015 12:33 am
MyCo wrote:Most likely there is something wrong with your user data. Maybe a recovery schematic or broken modules in the toolbox. Try temporarly renaming that folder so that FS can't find it anymore:
%appdata%\FlowStone
Bingo! :P Thank you, MyCo, that helped. It was not the modules, though, not mine nor the system modules. Whatever it was, it seems to be isolated now. Thanks again. Boy what a service, issue resolved within less than 4 hours on a Saturday night! :lol:
Postby RJHollins » Sun Mar 22, 2015 12:39 am
Glad you're up and running !
We NEED you :D
:lol:
Postby martinvicanek » Sun Mar 22, 2015 1:16 am
RJHollins wrote:Glad you're up and running !
We NEED you :D
:lol:
You are flattering me. :oops:
Postby djbrynte » Sun Mar 22, 2015 10:41 am
:) MV is the best ! :D good its fixed!
djbrynte
Re: FS crashes at start, reinstall doesn't help (fixed)
Postby martinvicanek » Sun Mar 22, 2015 11:52 am
Thank you guys for your help and kind words. You rock!
