change image to grayscale on fly
Postby Logado » Thu Apr 02, 2015 7:47 am
This is possible on the fly to change the color of the image. Methods of work with images not found :cry:
Logado
Re: change image to grayscale on fly
Postby KG_is_back » Thu Apr 02, 2015 2:46 pm
In ruby, there are no methods to read or change pixels of a bitmap. In green, there are getPixel and setPixel prims, but to alter entire image you'd need enormous loops, which would likely create massive CPU waste.
KG_is_back
Postby tulamide » Thu Apr 02, 2015 4:12 pm
You could make use of the FreeImage Project. You would then download the FreeImage DLL (http://freeimage.sourceforge.net/download.html) and access the functions you need using Ruby's Win32API dll access as explained in the User Guide. It takes some time to set them up, but then you are able to do those on-the-fly conversions.
Postby Nubeat7 » Thu Apr 02, 2015 8:32 pm
there is also the color matrix, you can use this for changing colors of images.
Postby Youlean » Thu Apr 02, 2015 8:59 pm
Try this... (It is not mine pack)
gui pack.fsm
(31.31 KiB) Downloaded 814 times
Youlean
Postby Logado » Fri Apr 03, 2015 5:25 am
Thanks for answers.
I need it to show that the element is not active. Make a simple method.
v.drawBitmapSection @Spriteimg,[0,image_y,48,16],[0,0,6,2]
if @disable == 1
c1 = Color.new 180,53,60,70 #background color
c1 = Color.new 180,53,40,70
r = [0,0,v.width,v.height]
b = LinearGradientBrush.new r,c1,c2,0,true
v.drawRectangle b,r
Logado
Users browsing this forum: No registered users and 73 guests
