Sample acurate timing - well where?
Postby chackl » Tue Nov 06, 2012 11:43 am
Hello!
So Flowstone V3 was saing that the timing problem may be solved now. Or am i totaly wrong?
Since Timing war one of those problems why i stopped working 2 jeas ago with VSTi in SynthMaker ;)
So now it should be solfable: A sequenzing with midi. is that correct?
is there any example of that yet or is something coming?
Regards ;)
chackl
Re: Sample acurate timing - well where?
Postby Tronic » Tue Nov 06, 2012 12:16 pm
You can find in you tollbox the Ticker Custom, and can use it for generate better timing.
it works well with ruby ​​module,
but not with the redraw graphics, it remains always fixed with a maximum of 100Hz.
Tronic
Postby chackl » Tue Nov 06, 2012 12:22 pm
Tronic wrote:You can find in you tollbox the Ticker Custom, and can use it for generate better timing.
well but it dows not seem that it is accurate to the AUDIO Clock. And still with this module the sequencing part with midi is verry fishy. I've seen there is this Ruby component with "Frames". is there an example how to handle that? and generate midi or trigger signals with it?
Regards
chackl
Postby Tronic » Tue Nov 06, 2012 12:29 pm
the manual is an example of how to generate midi from ruby.
respect to generate trig from ruby module, I have not investigated.
Tronic
Postby support » Tue Nov 06, 2012 3:20 pm
Here's an example we've been working on for an arpeggiator module.
arp.fsm
(52.66 KiB) Downloaded 1231 times
To stay accurate all the timing critical stuff needs to be kept within a Ruby section. So that's inside a Ruby component or passed via Ruby Value or MIDI connectors. As soon as you convert back into triggered data you'll lose accuracy.
support
Postby chackl » Tue Nov 06, 2012 3:49 pm
support wrote:To stay accurate all the timing critical stuff needs to be kept within a Ruby section. So that's inside a Ruby component or passed via Ruby Value or MIDI connectors. As soon as you convert back into triggered data you'll lose accuracy.
Thanks! That is nice to know because i thought this would be possible. Well then i have to get up my ruby skills :D
Regards
chackl
Postby chackl » Tue Nov 06, 2012 3:51 pm
but i have to kno somethig :D
Is this timing holding too if the song gets exported an not played in one host?
Regards
chackl
Postby support » Tue Nov 06, 2012 4:13 pm
Not sure what you mean? Does the timing work when exported? Yes it does. The timing for MIDI is based on the audio buffer requests, it doesn't matter where they come from - could be FlowStone or an audio host.
support
Postby user_fm » Sun Nov 11, 2012 12:23 pm
support wrote:Here's an example we've been working on for an arpeggiator module.
arp.fsm
....means it makes no sense to extract float from mono stream with 1ms timer (1000 times per seconds) ?
user_fm
Postby nix » Mon Nov 12, 2012 5:15 am
That is one method also,
which is improved by Ruby's faster tick.
edit:PS- Wow support! Thanks a million for the arp module.
I love it- very useful. I'll try learn some Ruby stripping the non-essentials out,
functioning as a clock
nix
