Somewhat different peaking EQ filter
Postby martinvicanek » Thu Nov 19, 2020 9:27 pm
I had a little DSP excercise which kept me busy for two weeks or so. The objective was to create a bell-shaped filter which is more concentrated around the center frequency than the common RBJ biquad, but at the same time has a flat top. This is what I came up with.
biquad EQ.png (18.44 KiB) Viewed 18255 times
4th order EQ.png (17.49 KiB) Viewed 18255 times
The schematic includes a 5-band demo equaliser (stereo, optimized). Feel free to use, integrate into your projects and modify if you like.
EQ 4th order.fsm
(39.18 KiB) Downloaded 1347 times
Re: Somewhat different peaking EQ filter
Postby adamszabo » Fri Nov 20, 2020 12:37 pm
Very interesting, thanks!
adamszabo
Postby Spogg » Sun Nov 22, 2020 10:12 am
Very nice as always Martin!
It must be great to be able to think of a filter shape and behaviour and then be able to make it.
Thank you so much for sharing this and all your other amazing work.
Return to DSP
