FlowStone 3.0.8 SKYLARK(any bugs or issues)
Re: FlowStone 3.0.7 CHERRY (any bugs or issues)
Postby Father » Mon Jan 19, 2015 4:27 pm
Remember this feature from 3.0.6?: "clicking stop for a second time in your host will now stop all playing audio"
Very cool feature. But causes a CPU spike which is really annoying. Specially if you have multiple flow plugins loaded up, it may even cause a glitching sound while stopping all the audio. Just like the clear audio primitive module.
edit:
This one actually causes more problems than it solves. Even moving playback position, stopping recording or moving clips at the playlist, is causing significant CPU instability and glitches. Is it just me?
Father
Postby djbrynte » Sat Mar 21, 2015 3:52 pm
sounds glitchy.
djbrynte
Postby tester » Sat Apr 25, 2015 2:22 pm
Starting with 3.0.8 here
Re: FlowStone 3.0.8 SKYLARK(any bugs or issues)
Postby Perfect Human Interface » Sat Apr 25, 2015 2:54 pm
I can't test this currently (using the FL version), but I'm very interested in whether the major issues in the past few releases have been finally ironed out so I can finally get off 3.0.4. I don't see mention of any such thing in the release notes though.
Postby martinvicanek » Sat Apr 25, 2015 7:03 pm
Minor issue with the text box losing the cursor prompt after a while. Can't really say what causes it, only that it has occured more than once. Seems to be affecting only the text box, while everything else works allright. In that case just save your work and reopen FS - that's all.
Postby KG_is_back » Sat Apr 25, 2015 7:08 pm
This might be related to what Martin have found. When I edit code/text in assembler/text component sometimes the interface freezes - I'm unable to move modules around add/edit links, when I add new modules form toolbox, they don't show in the schematic (although they are there when I save and reopen the schematic) etc. It can be fixed by reopening flowstone.
KG_is_back
Postby MyCo » Sun Apr 26, 2015 1:43 am
Something is horrible wrong with the Text box (shortcut "a"). On my win8 machine this for example always crashs:
1. Create an empty schematic
2. Create a Text box (keyboard shortcut "a")
3. Click into it
4. Click outside of it
On my win7 notebook, it doesn't crash but I can't edit the text box content after that.
On my win8 virtualbox, I can edit the content after doing this, but repeating point 3 & 4 after having content in it leads to a crash after a while.
Postby Tronic » Sun Apr 26, 2015 8:46 pm
^ same here
Tronic
Postby tester » Mon Apr 27, 2015 8:11 am
I sent it to Malc.
Postby tester » Mon Apr 27, 2015 9:07 pm
Fixed in 3.0.8.1, ready to download.
