Only one Button? Can't automate it outside...
• Page 2 of 2 • 1, 2
Re: Only one Button? Can't automate it outside...
In what way(s) exactly did KG's example above not accomplish your task?
- Perfect Human Interface
Perfect Human Interface wrote:In what way(s) exactly did KG's example above not accomplish your task?
It triggers, but I still can't link it anymore inside the DAW:
- Nowhk
Nowhk wrote:No, I need a "Button", not a "Switch". A Switch once I release the mouse doesn't return to its original position, it remains pressed.
ok, i thionk i know what you mean now,
if mouse left button is down then state should be on
if mouse left button is up then state is off
is that right?
if so it is a switch which switches between 2 states! while the stock "button" only sends a trigger and no state
for this you need to change the code a bit in the switch, so that the state changes to true on mouse down and to false on mouse up
this should work as expected:
on mouse down.fsm- (288.11 KiB) Downloaded 873 times
Nubeat7 wrote:this should work as expected:
Yes, seems to works. I've added it on Toolbox, and seems to does the task
Unfortunatly, on FL, I need to load the button, save the project and reload it before it starts.
In FlowStone standalone that's not happens. Bug? I don't know, but seems to do the task
If I found trouble I'll up the topic again
- Nowhk
