is it possible to load synth and after loading it loads?
I have seen now that sylenth load like this.
sylenth is loaded and then it comes in the sequencer.
I mean first sylenth is loaded and afgter its loaded it takes like 1 second when synth is up?
i mean so it loads faster and then it styart loading the presets
or something like that?
- djbrynte
Re: is it possible to load synth and after loading it loads?
Exo used a technique to do this. When FS plugin loads, all afterload triggers count to the loading time. You may use "trigger thread" prim to start new thread, which does not count to loading time when used. I do not have an example at hand now...
ok but it seem like its possible
- djbrynte
