Logarithmic Volume Control (dB FS)
It seems there doesn't exist one, so I created one.
http://flowstone.guru/downloads/logarithmic-volume-control-db-fs/
(Don't forget to rate it, good or bad doesn't matter, just do it
Re: Logarithmic Volume Control (dB FS)
why don't you use the showCursor method to show/hide the cursor instead of the primitive version?
Something doesn't add up... at -6dB I would expect the scaling factor would be 0.5, instead it is 0.4 which is ~ -8dB
BTW: you skipped the difficult part: presets & default
MyCo - Posts: 718
Because of the hold state.MyCo wrote:why don't you use the showCursor method to show/hide the cursor instead of the primitive version?
I hate doing careless mistakes. You are right. When inverting 20*log10(n), instead of 10^(n/20) I wrote 20^(n/20). I'm very sorry, will be corrected in an update soon!MyCo wrote:Something doesn't add up... at -6dB I would expect the scaling factor would be 0.5, instead it is 0.4 which is ~ -8dB
What's so difficult in sending a float to the preset manager?MyCo wrote:BTW: you skipped the difficult part: presets & default
I'd say, programming a control would be the difficult part
tulamide wrote:What's so difficult in sending a float to the preset manager? I'd say, programming a control would be the difficult part
Tried it? The tricky part is, that you have to send values to the preset, and you have to set your control to the values coming from the preset. Done incorrectly, this can lead to an endless loop
MyCo - Posts: 718
MyCo wrote:Tried it? The tricky part is, that you have to send values to the preset, and you have to set your control to the values coming from the preset. Done incorrectly, this can lead to an endless loop
Well, I never had such issue, but if the people vote for it, because they can't do it themselves, I'll add a float preset parameter.
tulamide wrote:Well, I never had such issue, but if the people vote for it, because they can't do it themselves, I'll add a float preset parameter.
I haven't had problems with it, but I'm not sure why the stock knobs for example use such a weird construct (toggling "Rec" input). My approach is a lot simpler than that.
MyCo - Posts: 718
New version 1.01 is up. See changelog for a description.
Very nice! So how would you integrate it with a preset manager (preset name, value, default)?
wow, very cool knob Tom i really like it, about the presetmanager thing, i normally use this module which scales linear 0..1 to log db it has an min db and max db value in the properties, its independent from the control so every knob or slider could be used..
db volume nubeat.fsm- (254.64 KiB) Downloaded 1863 times
@Nubeat, same as I do. Every single knob / slider, whatever in my projects goes from 0 to 1. Scaling is applied outside of the control module. That way I don't have to check the ranges on every control, when I want to change something later...
MyCo - Posts: 718
