Quilcom QX7 Mods
Quilcom QX7 Mods
Postby newdsp » Fri Jan 08, 2021 5:39 am
Here are a few mods for QX7. Version 1.13 has stereo random panning on the delay effect (sounds way better when the feedback is high) and v1.14 changes the colors when the RESET button is pressed. So... Don't press it. Stay away from it. Don't touch it. Version 1.15 has the pan speed set by the delay time.
Quilcom QX7 v1.15 .fsm
This one has the panning rate proportional to the delay time. Works in FS 309b2.
(1.76 MiB) Downloaded 933 times
Quilcom QX7 v1.14 .fsm
FS 309b2.
(1.76 MiB) Downloaded 915 times
Quilcom QX7 v1.13 .fsm
Works in FS 309b2.
(1.76 MiB) Downloaded 907 times
newdsp
Re: Quilcom QX7 Mods
Postby newdsp » Fri Jan 08, 2021 8:14 am
I had to completely change the delay effect to add the 3/16 note.
Quilcom QX7 v1.16 .fsm
(1.77 MiB) Downloaded 914 times
newdsp
Postby newdsp » Fri Jan 08, 2021 8:02 pm
Here is another version with the UI re-arranged to be more consistent but it's still not finished. I also had to re-wire the delay panner to turn on only when the delay is turned on. Maybe it should be a separate module. I also disconnected the master volume from the preset manager so that when you change presets the volume remains the same.
Quilcom QX7 v1.17 .fsm
(1.55 MiB) Downloaded 918 times
newdsp
Postby newdsp » Sat Jan 09, 2021 4:54 am
Here is the latest modified version of QX7. Link is in the video description but also here.
https://youtu.be/rJEbWMWYG4A
https://drive.google.com/file/d/1NTYqlA ... sp=sharing
FM-X.fsm
(102.01 KiB) Downloaded 907 times
Quilcom QX7 v1.18 .fsm
(2.09 MiB) Downloaded 963 times
newdsp
