Quilcom QX7 Mods
Quilcom QX7 Mods
Here are a few mods for QX7. Version 1.13 has stereo random panning on the delay effect (sounds way better when the feedback is high) and v1.14 changes the colors when the RESET button is pressed. So... Don't press it. Stay away from it. Don't touch it. Version 1.15 has the pan speed set by the delay time.
Quilcom QX7 v1.15 .fsm- This one has the panning rate proportional to the delay time. Works in FS 309b2.
- (1.76 MiB) Downloaded 933 times
Quilcom QX7 v1.14 .fsm- FS 309b2.
- (1.76 MiB) Downloaded 915 times
Quilcom QX7 v1.13 .fsm- Works in FS 309b2.
- (1.76 MiB) Downloaded 907 times
- newdsp
Re: Quilcom QX7 Mods
I had to completely change the delay effect to add the 3/16 note.
Quilcom QX7 v1.16 .fsm- (1.77 MiB) Downloaded 915 times
- newdsp
Here is another version with the UI re-arranged to be more consistent but it's still not finished. I also had to re-wire the delay panner to turn on only when the delay is turned on. Maybe it should be a separate module. I also disconnected the master volume from the preset manager so that when you change presets the volume remains the same.
Quilcom QX7 v1.17 .fsm- (1.55 MiB) Downloaded 919 times
- newdsp
Here is the latest modified version of QX7. Link is in the video description but also here.
https://youtu.be/rJEbWMWYG4A
https://drive.google.com/file/d/1NTYqlA ... sp=sharing
FM-X.fsm- (102.01 KiB) Downloaded 907 times
Quilcom QX7 v1.18 .fsm- (2.09 MiB) Downloaded 963 times
- newdsp
Users browsing this forum: Google [Bot] and 4 guests
