FINALLY - a way to to OVERSAMPLE your schematic for real!!!
Re: FINALLY - a way to to OVERSAMPLE your schematic for real
Postby Halon » Sat Sep 15, 2018 8:56 pm
I might try this in of of my current projects. Thanks for this!
Halon
Postby StereoSpace » Sun Jan 10, 2021 3:00 am
Guys, please help. As far as I know, in the alpha version I cannot apply upsampling more than 4x. But my problem is that I can't figure out how to connect any effect that already has a packed input, if the upsampling output already has packed connectors. Just pack it up again? but it seems to me that this is not the right solution.
I don't need more than 4x for experiments, but I can't figure out how to do it correctly. probably a stupid question from me ...
How_connect_it_2.fsm
Please, help me!
(141.89 KiB) Downloaded 1260 times
GUI designer
StereoSpace
Postby JWP » Fri Jan 15, 2021 9:46 pm
Gave this a test drive in v3.0.9b2-3457.
Tested:
Standard Oscillator_Oversampled.fsm
(198.79 KiB) Downloaded 1369 times
64bit VST2 & 3
32Bit VST2 & 3
All crash FL 20.8.1, even when using the 32 bit version of FL.
JWP
Return to DSP
