(RUBY) Array as argument list
Postby tulamide » Mon Jun 22, 2015 4:20 pm
You may already know that you can use the splat operator followed by an array to define a list of arguments. That's helpful if you have a method that works with any number of arguments:
def sum *args
   sum = 0
   args.each do |n|
      sum += n
   return sum
sum 1, 2, 3, 4, 5, 6
#returns 21
But, it also works the other way round. Imagine, you have an array structured like this
myArray = [x, y, z, x, y, z, x, y, z]
and a method like this
def translate x, y, z
   n = x * z + y * z
   #do cool stuff
You can easily use the array without intermediate steps like so
translate *myArray[0..2]
#takes the first 3 elements of myArray and passes them as arguments
Happy Programming :D
