deleted by uploader
deleted by uploader
Postby tiffy » Sat Aug 15, 2015 10:17 am
deleted
tiffy
Re: Image Resizer v1.3
Postby Nubeat7 » Sat Aug 15, 2015 5:50 pm
if you want to zoom in for bigger sizes as the original or loading bigger images then the display the sliders are not working correctly, you just see a part of the image, to fix this issue you would need to use the translate primitive..
i did a 'zoom and scroll' module once for your colorpicker tool which should do the job correctly..
image zoom and scroll nubeat7.fsm
(70.04 KiB) Downloaded 1138 times
