Wich book best for learning Ruby in Flowstone?
• Page 2 of 3 • 1, 2, 3
Re: Wich book best for learning Ruby in Flowstone?
Thanks Infuzion, the monk seems great and easy reading.
As most books are in english and it's not my mothertonghue then easy readability comes in handy.
jjs - Posts: 142
+1 for the monk
think I start to get a hang of the basics. but when it comes to more advanced stuff I get a little lost.
my method is to just run through the tutorial/reading until I loose track of things. then I take a good break for a day or five then I go back to the beginning and run through it again. each restart makes me go a-ha! and I get a little further before I again loose track of the theory I'm reading. slowly getting the hang of Rubydubie
- tor
same for me, sometimes i get lost
also the manual of flowstone wich i first forgot, gives a good start and then one of the links or books must help
and yes repeating after a few days
success!
success!
jjs - Posts: 142
Here's another one I just found yesterday...
The B*st*rds Book of Ruby
...despite the shocking title, it actually seems very well written and explained. It is arranged more around the concepts that you need to understand, rather than an overwhelming method by method analysis.
For me that has been the key. The learning curve seemed very steep at first, especially as I never used anything object oriented before. But now that I've tinkered some more, it seems like it is a very consistent and forgiving language once you do get the basic concepts nailed, so the learning curve seems to be flattening out quite quickly.
Looks good!
Very nice, thanks Trog.
jjs - Posts: 142
Hi
I made advanced ruby on rails online course
your opinions are welcome !
this courses are for skilled developers and deals with picky subject : chatbot, AI, blockchain
- rubyrailsninja
Here is some book suggestion by me that is used to lean Ruby
Beginning Ruby by Sandi Metz - The best beginner friendly book to learn Ruby
Programming Ruby
Programming Ruby
- kiash
kiash wrote:Here is some book suggestion by me that is used to lean Ruby
Programming Ruby
Thank-You !
I think i will first start with the FS manual on Ruby and the pragmatic guide wich i also have.
- rioshare
That's a great choice! The FS manual and the Pragmatic Guide are both excellent resources for learning Ruby.
The FS manual is a comprehensive guide to the Ruby programming language. It covers everything from the basics of syntax and semantics to more advanced topics like object-oriented programming and metaprogramming. The Pragmatic Guide is a more concise and focused guide that is aimed at experienced programmers who want to learn Ruby quickly.
I would recommend reading the FS manual first, as it will give you a good foundation in the Ruby language. Once you have a basic understanding of Ruby, you can then read the Pragmatic Guide to learn more about the language and to get some practical advice on how to use it.
Here are some other resources that you may find helpful:
vidmateapp
Ruby documentation: https://ruby-doc.org/
Ruby tutorial: https://www.tutorialspoint.com/ruby/
Ruby community: https://ruby.dev/
I hope this helps!
vidmateapp
I hope this helps!
- JeffreyFisher
