Convert String with Different Range Types to Array or String
Ruby - Convert a String of Values also Containing 2 or More Different Range Types ("-" and "..") to a Sorted Array or String Containing Only Values.
The Schematic should not display an error if any or all of the Ranges or Range Types ("-" and "..") are not present in the Input String.
Flowstone v3.0.6 Pebble.
Convert String with Different Range Types to Array or String.FSM- Flowstone v3.0.6
- (990 Bytes) Downloaded 1035 times
tiffy - Posts: 400
Re: Convert String with Different Range Types to Array or St
Thanks TIFFY !
Always appreciate the 'specialty' modules you post.
Works great ... Toolbox entry
Great little gadget! thanks
kortezzzz - Posts: 763
