Custom DSP Code 2 (comunity project)
Re: Custom DSP Code 2 (comunity project)
Postby KG_is_back » Mon Oct 26, 2015 6:55 pm
OK guys... update time... DSPC now supports functions to be added. min, max and abs functions are already added. Unfortunately I haven't got time to write any documentation yet, nor make the adding more user-friendly. Arrays are still not supported, nor loop and hop statements.
DSPC3.1.fsm
(11.81 KiB) Downloaded 992 times
KG_is_back
Postby KG_is_back » Wed Oct 28, 2015 8:26 pm
Arrays now work too (be careful - index overflow is not checked by default) and I've added sin1, cos1, tan1, log2, and pow(a,b) functions (adapted from MartinVicanek's stream math functions). It would be helpful if some of you guys tested the DSPC3 with some codes you come up with and PM me any potential errors.
DSPC3.1_test.fsm
(16.31 KiB) Downloaded 1024 times
KG_is_back
Postby KG_is_back » Fri Oct 30, 2015 4:30 pm
Major bugfixes...
also added hop and loop statements. And a few new functions: "to_f(x)" converts integer to float "to_i(x)" vice versa and "trunc" converts float to integer with truncation (it means only whole number part counts example: to_i(2.7)=>3 but trunc(2.7)=> 2).
Also guys do you want detailed manual in pdf or something?
DSPC3.2.fsm
(16.44 KiB) Downloaded 999 times
KG_is_back
Postby tester » Fri Oct 30, 2015 5:21 pm
Why not?
Postby Spogg » Fri Oct 30, 2015 7:04 pm
Yes please!!
Postby KG_is_back » Sat Oct 31, 2015 3:15 am
Here's a documentation on all the features... I've haven't documented the part about adding new functions yet, because it's complicated. I will add that soon...
DSP Code v3.rar
(21.26 KiB) Downloaded 1156 times
KG_is_back
Postby Spogg » Sat Oct 31, 2015 9:10 am
Many thanks for doing this KG :D
I intend to start playing with this properly after you have declared it finished so will you be in a position to do this soon? Until I retire my time is limited you see...
Postby KG_is_back » Sat Oct 31, 2015 2:16 pm
Spogg wrote:Many thanks for doing this KG :D
Well... the thing is... compilers are like MMORPG (like world of warcraft) - you never really finish it - you just level up. The compiler is already working good enough to be usable in projects. In fact, feedback from real-life users will help me find and fix bugs faster. I myself found and fixed many bugs by using it in my projects. SO GUYS, START USING IT PLEASE - IT SPEEDS UP DEVELOPMENT!
KG_is_back
Postby KG_is_back » Mon Nov 02, 2015 4:27 pm
Here is an updated manual and latest version of DSPC3. Guys, please read it and point out any errors. Also if you know a little assembly and ruby, try to make your own function according to the tutorial, to see if it's clear enough.
DSPC3.2.fsm
the compiler
(16.71 KiB) Downloaded 1026 times
DSP Code v3.rar
the manual
(34.84 KiB) Downloaded 1181 times
KG_is_back
Postby tulamide » Mon Nov 02, 2015 4:33 pm
I would really like to help. But I am so untalented when it comes to DSP code, that I simply am the wrong guy for this task. But since your module is such a great help for all people who do their own dsp codes, I really, really hope you will get some support!
