Ruby - Asynch cycling with waiting
Postby Nowhk » Mon Nov 09, 2015 4:58 pm
Hi all,
I have this code:
# init variables
def init
# event handler
def event i,v,t
   if i==1 then startLFO(t)
def startLFO(t)
   for i in 0..100
      sleep 1
      watch "test",i
      if i==90 then
         i=0
I'd like to iterate from 0 to 99 every (let say) 1 second, so I can see a sort of progression, without that the interface freeze. So a sort of wait-process, threaded.
Than, once I got the end, restart from 0. (I'm making a sort of custom LFO, with values that will be stored in an array and freq which is the "sleeping" time).
Where am I wrong? My DAW crash with that code...
Thanks!
Nowhk
Re: Ruby - Asynch cycling with waiting
Postby tulamide » Mon Nov 09, 2015 5:26 pm
Nowhk wrote:I'd like to iterate from 0 to 99 every (let say) 1 second, so I can see a sort of progression, without that the interface freeze. So a sort of wait-process, threaded.
Create two trigger buttons. Create two trigger inputs in your RubyEdit and name them "start" and "stop". Connect the buttons with the inputs.
Use this code:
def init
   @iteration = 0
   @end = false
def event i, v
   if i == "start"
      @end = false
      cycle
   elsif (i == 99) and (@end == false)
      cycle
   elsif i == "stop"
      @end = true
def cycle
   @iteration += 1
   if @iteration == 100
      @iteration = 0
   watch @iteration
   input 99, nil, time + 1
This is a basic asynchronous loop.
Postby Nowhk » Mon Nov 09, 2015 5:32 pm
Use this code:
def init
   @iteration = 0
   @end = false
def event i, v
   if i == "start"
      @end = false
      cycle
      cycle
   elsif i == "stop"
      @end = true
def cycle
   @iteration += 1
      @iteration = 0
   watch @iteration
Thanks for the reply. Uhm, in fact is that I need to work with play/stop of DAW, not triggering buttons...
Nowhk
Postby tulamide » Mon Nov 09, 2015 5:42 pm
There's a prim called "Playing". The non-stream version sends out a boolean. Connect it with a boolean input of the RubyEdit and name that input "playing". Change the event code with this one:
def event i, v
   if i == "playing"
      if v == true
         @end = false
         cycle
      elsif v == false
         @end = true
      cycle
Postby Nowhk » Mon Nov 09, 2015 5:48 pm
I see. But uhm, the iteration is made calling the "event" function itself for what I see. What if I'd like to make 4 different/parallel asynch/waiting process? I risk that when I recall an event I don't know which target function call.
I mean: 4 different iteration, after 1,2,3,4 seconds respectively (that will use 4 different arrays of values, for example).
In this wait I can't...
Nowhk
Postby tulamide » Mon Nov 09, 2015 6:04 pm
I know people don't like to hear it. But you should read the user manual about Ruby. I used just one input (the one with index 99). You can use as many as you like. And since they are indexed, you know which input belongs to which cycle. You can cycle with different methods or extend the existing method to manage several different cycles.
Postby Nowhk » Tue Nov 10, 2015 9:23 am
Got it:
def init
   @end = false
   @lfo_index_1 = 0
   @lfo_freq_1 = 0.008
   @lfo_index_2 = 0
   @lfo_freq_2 = 0.05
def event i, v
   if i == "start"
      @end = false
      lfo_1
      lfo_2
   elsif (i == 10) and (@end == false)
      lfo_1
   elsif (i == 20) and (@end == false)
      lfo_2
   elsif i == "stop"
      @end = true
def lfo_1
   @lfo_index_1 += 1
   if @lfo_index_1 == 100
      @lfo_index_1 = 0
   watch "LFO 1: ", @lfo_index_1
   input 10, nil, time + @lfo_freq_1
def lfo_2
   @lfo_index_2 += 1
   if @lfo_index_2 == 100
      @lfo_index_2 = 0
   watch "LFO 2: ", @lfo_index_2
   input 20, nil, time + @lfo_freq_2
Thanks! Not sure which "input" number to use, I guess every number is ok (I've used 10 and 20 in this case).
Nowhk
Postby Nowhk » Tue Nov 10, 2015 11:12 am
Another little question: how can I stop a previous triggered function? If I click on the trigger button "start" two time, it invoke the function again, so I can see two events working together.
Is there a way to "retrigger" and/or stop the previous function thread?
Nowhk
Postby tulamide » Tue Nov 10, 2015 4:59 pm
That goes beyond "simple".
The first question was relatively easy to answer. But it begins to get way more complex now, and I can't spend the time for it. You should consider using classes. Also, differentiating the different "threads" (they aren't real threads) can be done by using IDs.
Maybe someone else can go into more detail?
Users browsing this forum: No registered users and 37 guests
